6 years ago
2019年11月1日 GMT+1 14:16
Dear Veda,
I am fairly new to Comsol as well, but I might be able to give an answer.
I could explain myself, but what I found on Comsol's own documentation is way clearer (this is from their website on the CFD module (here):
"With the addition of the Structural Mechanics Module, fluid-structure interaction (FSI) problems can be defined and solved for both laminar and turbulent flow. Two FSI options are available in the CFD Module:
- One-way FSI coupling, in which the flow creates a load on a structure, but the deformations are small enough to neglect their influence on the flow
- Two-way FSI coupling, in which the flow creates loads on a structure, but the deformations are large and influence the flow by changing the shape of the fluid domain
The two-way coupling defines a moving mesh problem in the fluid domain. The displacements at the solid-fluid surfaces are determined by the balance of forces exerted by the fluid and counterforces exerted by the deforming solid structure. Steady-state and time-dependent studies are available for both one-way and two-way FSI problems for laminar and turbulent flows."
Hope this helps!
Dear Veda,
I could explain myself, but what I found on Comsol's own documentation is way clearer (this is from their website on the CFD module ([here](https://www.comsol.com/cfd-module)):
1. One-way FSI coupling, in which the flow creates a load on a structure, but the deformations are small enough to neglect their influence on the flow
2. Two-way FSI coupling, in which the flow creates loads on a structure, but the deformations are large and influence the flow by changing the shape of the fluid domain
Hope this helps!
