Time-dependent results are different with different time-range
Posted 2022年8月15日 GMT+2 16:53 0 Replies
Hi, I used the time-dependent simulation, and I set the time range from 1e-6 to 10,100,1000 in logrithum, there are 10 steps per decade. But I found that the starting point of the simulated results in these three time ranges are different, from log windown, it looks like the finer meshing density is used for the shorter time ranges, But I checked the solved nember of degrees of freedom, they are same for every time range. Did you meet this problem before? Could you give me some suggestions on this?
Thanks, Shan
Hello Shan Zhang
