MUMPS memory allocation factor increased
Please, how do I fix the error:MUMPS memory allocation factor increased?
1 Reply Last Post 2023年7月4日 GMT+2 08:53
Posted: 2 years ago 2023年7月4日 GMT+2 08:53
This is an information message, not an error. Unless the solution fails for other reasons, or is unphysical, you need not to worry.
However, the meassage indicates that the structure of the stiffness matrix is changing in unexpected ways during solution, so there may well be an underlying problem in the physics. As an example, you sometimes encounter this type of message in nonlinear structural mechanics when a structure turns inside-out due to unphysical material data.
Henrik Sönnerlind
COMSOL
This is an information message, not an error. Unless the solution fails for other reasons, or is unphysical, you need not to worry. However, the meassage indicates that the structure of the stiffness matrix is changing in unexpected ways during solution, so there may well be an underlying problem in the physics. As an example, you sometimes encounter this type of message in nonlinear structural mechanics when a structure turns inside-out due to unphysical material data.
