Study error
Hi everyone, How can I resolve the error below?
  • Feature: Compile Equations: Stationary (sol1/st1) Error in multiphysics compilation. Syntax error in expression.
    • Expression: 1.37422247E9*^1
    • Subexpression: *^1
    • Position: 13
    • Table row: 1
    • Table column: 3
    • Function name: SyfuncEngg_fused_filament_fabrication_tested_at_20C_5_mm_min_dos_Santos_et_al_tested_to_fracture_4
1 Reply Last Post 2024年9月5日 GMT+8 18:45
Magnus Ringh COMSOL Employee
Posted: 2 years ago 2024年9月5日 GMT+8 18:45
Hi Alexander,
Check your expression;1.37422247E9*^1is not a correct syntax.1.37422247E9*10^1, for example, would work even if it does not make much sense with an exponent of 1.
Magnus
Hi Alexander, Check your expression; `1.37422247E9*^1` is not a correct syntax. `1.37422247E9*10^1`, for example, would work even if it does not make much sense with an exponent of 1. Best regards, Magnus
