Calculating contact area
Is there any way to calculate the contact area of a contact pair within COMSOL (ie without having to post-process data in MATLAB, which I have yet to try)? I have tried surface integration and other options under "Derived Values" to no avail.
7 Replies Last Post 2017年2月14日 GMT+1 21:28
Posted: 1 decade ago 2013年2月5日 GMT+1 07:54
if you integrate a Boolean equation on the contact pressure, when its over a given limit value you can get a reasonable contact area surface out (you can also plot it like that to see the shape to check
Hi if you integrate a Boolean equation on the contact pressure, when its over a given limit value you can get a reasonable contact area surface out (you can also plot it like that to see the shape to check -- Good luck Ivar
Posted: 1 decade ago 2013年2月5日 GMT+1 15:22
Excellent! Thank you.
Posted: 1 decade ago 2015年4月17日 GMT+2 12:05
I also have the same question. But I am not sure what is the meaning by " integrate a Boolean equation on the contact pressure". Thank you.
Posted: 1 decade ago 2015年4月17日 GMT+2 16:29
Hi Chengzhi,
If the contact pressure is called say solid.Tn then the Boolean operation is (solid.Tn>0). This expression gives a value of one when the pressure is positive, zero otherwise. If you integrate it over a surface it gives the area of the region that is in contact.
Nagi Elabbasi
Veryst Engineering
Hi Chengzhi, If the contact pressure is called say solid.Tn then the Boolean operation is (solid.Tn>0). This expression gives a value of one when the pressure is positive, zero otherwise. If you integrate it over a surface it gives the area of the region that is in contact. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2015年4月17日 GMT+2 20:11
One issue with Booleans is they are sensitive to small changes in mesh. An alternative is to use a function which goes from 0 at 0 to 1 at high values, for example:
f = (P/P0)^2 / [ 1 + (P / P0)^2 ]
for some threshold pressure P0.
One issue with Booleans is they are sensitive to small changes in mesh. An alternative is to use a function which goes from 0 at 0 to 1 at high values, for example: f = (P/P0)^2 / [ 1 + (P / P0)^2 ] for some threshold pressure P0.
Posted: 9 years ago 2016年3月13日 GMT+1 16:07
I have a 2D model costituited by elastomer (rectangular block) that sliding on rigid (square) pyramidal substrate; how can i estimate effective contact area of elastomer? How can i set Contact penality setting? i attach my file, where i wrong? Please someone answer me, thank you previously
Hi, I have a 2D model costituited by elastomer (rectangular block) that sliding on rigid (square) pyramidal substrate; how can i estimate effective contact area of elastomer? How can i set Contact penality setting? i attach my file, where i wrong? Please someone answer me, thank you previously
Posted: 8 years ago 2017年2月14日 GMT+1 21:28
Hello Nagi,
I have tried to use your method to evaluate the contact area for each step in a simulation with multiple load steps. I have a 2D-axisymmetric geometry and have probed the relevant boundary with the following expression: (solid.Tn < 0.01). The probe is made to integrate over the boundary nodes, so that the contact area (in 2d-axi collapsed state) is found.
The probe produces a plot which looks reasonable, however the recorded values of the probe are stored as NaN in the relevant table. If I try to update the probe, it returns the following error:
Undefined variable.
- Variable: comp1.solid.Tn
- Geometry: geom1
- Boundary: 14
- Expression: 1000000*(comp1.solid.Tn<0.01)
Enabling the "Compute surface integral" does not change the situation. Neither does "summation over nodes" instead of integration.
Do you have any suggestions on how to move on from here?
Kind regards,
Andreas
Hello Nagi, I have tried to use your method to evaluate the contact area for each step in a simulation with multiple load steps. I have a 2D-axisymmetric geometry and have probed the relevant boundary with the following expression: (solid.Tn < 0.01). The probe is made to integrate over the boundary nodes, so that the contact area (in 2d-axi collapsed state) is found. The probe produces a plot which looks reasonable, however the recorded values of the probe are stored as NaN in the relevant table. If I try to update the probe, it returns the following error: Undefined variable. - Variable: comp1.solid.Tn - Geometry: geom1 - Boundary: 14 Failed to evaluate expression. - Expression: 1000000*(comp1.solid.Tn
