Parametric Sweep Interpolation Results
Posted 2024年11月21日 GMT+8 00:590 Replies
I have run a tensile test parametric sweep where the sample is strained to 80% nominal strain at a rate of 10% strain per second in a time-dependent calculation. I would like to create a plot showing the strain at which each curve crosses the 5 kPa stress mark.
I believe this might involve using an interpolation function, but I am unsure about the exact syntax or setup. When I run a boundary probe for stress, the output table contains columns for modulus (μ), time, and stress. I am not sure how to extract the specific strain values corresponding to the 5 kPa stress from this table for each corresponding modulus sweep.
Would a parametric curve approach work better, or is there a way to process the probe results directly to get what I need?
Attached is the result from my simulation.
Hello Keefe Manning
