COMSOL Employee
2 years ago
2024年12月20日 GMT+8 21:47
Updated:
2 years ago
2024年12月20日 GMT+8 22:15
Hello Sergey,
If this system is axisymmetric, then you should select 2D axisymmetric in the Model Builder. Then you will see that in the Graphics window when you are drawing the geometry the axis of revolution r=0 is shown; you should draw (half of what you currently have in your screenshots) on the r>=0 half.
For an example, seethis tutorialormany others in the Application Gallery. Best,
Hello Sergey, If this system is axisymmetric, then you should select 2D axisymmetric in the Model Builder. Then you will see that in the Graphics window when you are drawing the geometry the axis of revolution r=0 is shown; you should draw (half of what you currently have in your screenshots) on the r>=0 half. For an example, see [this tutorial](https://www.comsol.com/model/steady-state-2d-axisymmetric-heat-transfer-with-conduction-453) or [many others in the Application Gallery](https://www.comsol.com/models?q=axisymmetric). Best, Jeff
2 years ago
2024年12月20日 GMT+8 21:54
Thank you very much.
2 years ago
2024年12月20日 GMT+8 23:16
If the system as a whole is not axisymmetric (another Langevin appears, located nearby, and the elements above them are not axisymmetric), then what to do? It is also possible to draw this in 3D, but the calculation will be very, very long, if it is calculated at all.
COMSOL Employee
2 years ago
2024年12月20日 GMT+8 23:31
A 2D axisymmetric analysis can only be performed if the phenomenon is indeed axisymmetric. You may need to (try to) go 3D.
2 years ago
2024年12月20日 GMT+8 23:40
Got it. Thank you.
