2 years ago
2025年1月25日 GMT+8 07:38
I think you want to model thermal expansion due to temperature variation. This is a built-in multiphysics coupling using Solid Mechanics and Heat Transfer in Solids. No need for moving mesh.
COMSOL Employee
2 years ago
2025年1月27日 GMT+8 21:39
Updated:
2 years ago
2025年1月27日 GMT+8 21:44
Hello Rayian,
As David pointed out, thermal expansion in solids is pre-implemented in the software. Note that this is a feature found in the optional Structural Mechanics Module and in the optional MEMS Module. To see if your license includes either of these two products, go to File > Licensed and Used Products.
It is also possible to add thermal expansion without either of those modules by adding terms to the equations, as illustrated inthis tutorial.
Hello Rayian, As David pointed out, thermal expansion in solids is pre-implemented in the software. Note that this is a feature found in the optional Structural Mechanics Module and in the optional MEMS Module. To see if your license includes either of these two products, go to File > Licensed and Used Products. It is also possible to add thermal expansion without either of those modules by adding terms to the equations, as illustrated in [this tutorial](https://www.comsol.com/model/thermal-microactuator-simplified-16357). Best regards, Jeff
