2013年2月26日 GMT+1 08:03
there is no "one solution" for fixing a topology issue when meshing ;)
But you should get some indications where (coordinates) or which boundary you have the problem.
Then think of how you might cut your domain in 2 or more such to ease the meshing, and mesh by "shunks" or pre-mesh some boundaries manually, some edges ...
2013年4月12日 GMT+2 20:43
I solved my problem! I had the same error. I am simulating a nano antenna which is not very complicated, but is very small in some parts. I had several errors in mesh part and defined meshes for the edges, but it did not helped. So I defined different sections for specific points and I do not have any errors now.
Zahra
Zahra
2014年6月7日 GMT+2 01:45
I am working on very simple cylindrical geometry. I am using heat transfer through solids and surface to ambient radiation. I made a central line in the cylinder, as i need temperature distribution along this line. When I go for finer meshing. I am getting 'A problem arose from when building mesh feature 'free tetrahedral 1a {ftet1}''. Please help !
2014年6月9日 GMT+2 08:19
Do you mean that you drew a line under Geometry node? In order to find, say, a temperature distubution along a line you do not need to draw it, but define a 3D Cut Line under Results --> Data Sets node.
Lasse
Lasse
