Uncertainty in deflection of mechanical structures
Posted 2013年3月28日 GMT+1 18:08 1 Reply
I designed a silicon structure which is supposed to deflect in the transverse direction (Y axis) under axial buckling (compressive) force (applied along X axis). Even after increasing the number of iterations from default 25 to 500, the solution of the problem never converged. However, when I applied the same force in the opposite direction (tensile), the solution converged. I used the 'Structural Mechanics' module and performed 'Stationary' study find out the deflection.
There is equal probability for the transverse deflection to occur in either of the two transverse directions (+Y or -Y) when compressive buckling force is applied along X axis. In case of applied tensile stress along X axis, however, there is no possibility of transverse deflection but only a little stretching displacement along X axis.
Is it the uncertainty in the direction of deflection that is preventing the solution from converging in the first case? It seems that COMSOL lacks the capability to handle uncertainty or randomness on its own. Is there any other method that can be used to simulate mechanical models of random nature?
1 Reply Last Post 2013年3月28日 GMT+1 20:50
