Fluid Compression
I built a simple model for fluid compression in 2D FSI model.
A squre is build as fluid, and three sides of it are defined as wall, the other side in contacted with a PDMS membrane. There is a uniform pressure applied on the membrane.
From the result a simulated, I found the fluid did not play any role inside. Does anyone know how to solve this?
By the way, stationary study is used is this model. I try to use time dependent study, but once I use it, i got a lot of errors.
The file is attached.
I am deeply greatefull to you if you can solve or give any suggessions!
Rui
0 Replies Last Post 2013年4月3日 GMT+2 13:17
Hello Rui Zhu
