Fluid simulation of wind turbine generator
Hello!
I want to simulate the rotation process of wind turbine blades driven by wind, in order to observe the changes in the entire flow field and the forces between the blades and the fluid. I used the Fluid-multibody interaction, assembly module in fluid structure coupling, but I don't know how to couple the effect of wind on blades in a physical field. Does anyone have any good methods or relevant case recommendations?
Thank you!
