Perfect conductor
I am trying to simulate a microstrip resonator. I see that when I use a Perfect Electric Conductor as the stripline surfaces, the wave propagates along the surface of the metal, but if I replace it with a metal, say, copper, the wave does not travel along the strip.
I am using the RF modules, Electromagnetic wave, frequency domain.
2 Replies Last Post 2013年11月10日 GMT+1 08:34
Posted: 1 decade ago 2013年11月6日 GMT+1 10:29
You haven't selected any boundaries in the impedance boundary condition.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You haven't selected any boundaries in the impedance boundary condition. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 2013年11月10日 GMT+1 08:34
Thanks for the swift reply.
If I add an impedance boundary condition here, I am not able to select any boundary. It either says 'overridden', or 'not applicable'.
I think this is because the boundaries for impedance boundary condition should be the outermost boundaries, which, in this case, are the PMLs.
If I remove them, I still can't set an impedance boundary condition in the microstrip line, as it is the bottom surface of the copper layer.
Any way I could get around the problem?
Again, my goal here is to find the resonant frequencies and the Q factor for the resonator.
Thanks in advance.
Thanks for the swift reply. If I add an impedance boundary condition here, I am not able to select any boundary. It either says 'overridden', or 'not applicable'. I think this is because the boundaries for impedance boundary condition should be the outermost boundaries, which, in this case, are the PMLs. If I remove them, I still can't set an impedance boundary condition in the microstrip line, as it is the bottom surface of the copper layer. Any way I could get around the problem? Again, my goal here is to find the resonant frequencies and the Q factor for the resonator. Thanks in advance.
