negative stress = compressive stress ???
Thanks for your help.
So that means that the negative stress values (blue) in the picture are compressive stress?
Or expressed in another way:
What does the minus sign of a stress value mean?
1) direction of the stress vector in the coordinate system
2) compressive stress (negative value) in difference to tensile stress (positive value)
3) both
4) other
Christoph Mannal
June 20, 2010 9:10am UTC
I have a simple question. When my value of normal stress is negative, is it then a compressive stress in general. So if it is positive, is it then tensile stress?
Or does the minus and plus just mean in which direction the stress vector is pointing?
Thanks and kind regards!
C. Mannal
Reply | Reply with Quote | Send private message | Report Abuse
Moderator
June 20, 2010 5:28pm UTC in response to Christoph Mannal
Re: negative stress = compressive stress ?
what if you try something like this (its V4, check that it's the same in V3.5)
Attachments: StressSignTst.mph
Moderator
June 20, 2010 5:31pm UTC in response to Ivar KJELBERG
And here are the view (only that in V4 it's not easy to identify which legend corresponds to which graph, but as the countour is Von Mises and von Mises >0 you should be able to identify it still unambiguously)
Have fun Comsoling
Attachments: StressSign.JPG
5 Replies Last Post 2010年12月2日 GMT+1 07:19
Posted: 2 decades ago 2010年6月21日 GMT+2 18:49
So how do you define compression ? w.r.t. the Comsol up or down boundary ? as for COMSOL I believe to remember, the "normal" is pointing out of the subdomain and you have negative sign then it is compression, but on the other hand in my eample I applied the force in the -Y direction (also comprssion) and I got a negative sy.
isnt this hen a question of definition ?
Hi So how do you define compression ? w.r.t. the Comsol up or down boundary ? as for COMSOL I believe to remember, the "normal" is pointing out of the subdomain and you have negative sign then it is compression, but on the other hand in my eample I applied the force in the -Y direction (also comprssion) and I got a negative sy. isnt this hen a question of definition ? Ivar
Posted: 1 decade ago 2010年12月1日 GMT+1 20:33
I'm trying to find the normal stress after simulation by comsol4.0. It use to be sx_smsld in comsol 3.5a but I couldn't find it in comsol 4.0.
Could anyone help???
Hi, I'm trying to find the normal stress after simulation by comsol4.0. It use to be sx_smsld in comsol 3.5a but I couldn't find it in comsol 4.0. Could anyone help???
Posted: 1 decade ago 2010年12月1日 GMT+1 22:05
the Cauchy stress from the spatial frame remains sx, sy, sz, sxy... but now you need to use the prefix "solid.sx" instead of the suffix "sx_smsld" à la 3.5a
try a "CNTRL +Space" + Solid mechanics > ... in one of the plot variable fields
Hi the Cauchy stress from the spatial frame remains sx, sy, sz, sxy... but now you need to use the prefix "solid.sx" instead of the suffix "sx_smsld" à la 3.5a try a "CNTRL +Space" + Solid mechanics > ... in one of the plot variable fields -- Good luck Ivar
Posted: 1 decade ago 2010年12月1日 GMT+1 23:09
is the ts.sx equal to normal stress at x direction?
Posted: 1 decade ago 2010年12月2日 GMT+1 07:19
The "ts." stands for thermal stress physics, and "sx" for Cauchy stress along x (in the Spatial frame), check the doc, it's rather well described therein (>= v4.1)
Hi The "ts." stands for thermal stress physics, and "sx" for Cauchy stress along x (in the Spatial frame), check the doc, it's rather well described therein (>= v4.1) -- Good luck Ivar
