Store Solution and Apply as a Boundary Condition in Subsequent Run
Does anybody knows how to apply the results obtained at the outlet of first run back to the inlet as an inlet bounrady condition? Actually the objective is to study a flow in a long clyinder by making it in small cylinders and repeating the BCs from solution back to the inlet. This will save the memory and help in reducing the size of geometry while getting the same results which would actually be obtained in a long clyinder simulation.
regards
Naveed
2 Replies Last Post 2012年4月21日 GMT+2 10:14
Hello Naveed Akhtar
Posted: 1 decade ago 2012年4月20日 GMT+2 22:38
Hi, Have you been able to figure this out? I am having the same problem
Dan
Hi, Have you been able to figure this out? I am having the same problem Thanks, Dan
Posted: 1 decade ago 2012年4月21日 GMT+2 10:14
take a look at the periodic boundary conditions, I believe that is what you could consider
Hi take a look at the periodic boundary conditions, I believe that is what you could consider -- Good luck Ivar
