Heat transfer
I was just curious what the difference between ambient temperature and external temperature was. I am attempting to model the heat transfer through a thin sheet of aluminum using the heat transfer>conduction module in 3d. We are assuming the aluminium is placed in a vacuum with the walls of the vacuum at 170K. The initial temperature of the aluminum is 500K.
1 Reply Last Post 2010年7月13日 GMT+2 19:30
Posted: 1 decade ago 2010年7月13日 GMT+2 19:30
from what I remember you have T (or local/standard temperature dependent variable) and Tempref (for V3.5a), the reference temperature for differential thermal stress/strain. And you have External temperature Text for heat exchange i.e. convective cooling etc, and then ambient Temperature for heat radiative exchange Tamb.
Finally only T the "Temperature" is a dependent variable, the others are normally fixed or boundary conditions value
Hope this helps
Ivr
Hi from what I remember you have T (or local/standard temperature dependent variable) and Tempref (for V3.5a), the reference temperature for differential thermal stress/strain. And you have External temperature Text for heat exchange i.e. convective cooling etc, and then ambient Temperature for heat radiative exchange Tamb. Finally only T the "Temperature" is a dependent variable, the others are normally fixed or boundary conditions value Hope this helps Ivr
