Initial parameter value effects parametric sweep
Posted 2015年6月24日 GMT+2 18:17 RF & Microwave Engineering, Parameters, Variables, & Functions, Studies & Solvers 0 Replies
The parametric sweep node is set to sweep global parameter "lda" for a range of values.
The frequency in the Study 1: Frequency Domain node is set to f0. This is a global parameter defined as f0=c_const/lda
The final results (measuring sample reflection and transmission) differ depending on the value of lda set in the Global Definitions node.
The only other thing that is dependent on this value is the refractive index of my particle, defined using an interpolation from imported values, but I get the same effect if I change these to constants.
Can anyone help me fix this? I'm using ver 4.3a
Hello Daniel Traviss
