10 years ago
2015年11月13日 GMT+1 16:36
Hi Berry,
Expand the Results node, right click on "Derived Values". Choose "Maximum", and then select "Surface Maximum". That will allow you to select specific boundaries.
Under Results->right click Derived Values->Mouse over Maximum->Click Surface Maximum
David Hovsepian
COMSOL, Inc.
781-273-3322
Hi Berry,
David Hovsepian
COMSOL, Inc.
781-273-3322
10 years ago
2015年11月13日 GMT+1 16:38
Please see attached screenshot
10 years ago
2015年11月13日 GMT+1 16:42
Can I select half a surface? Or, how may I split a surface into two, an inside and outside, and then select the inside? (see alpha.jpg - of the selected surface, I want to select the innermost ring only)
For example, to display only a part of the geometry being evaluated, we can use a 'filter'. Can I do something similar for the surface maximum evaluation?
10 years ago
2015年11月13日 GMT+1 16:56
you might get around with a Boolean expression of the type
maxop1((x>0)*(y>0)*Max_variable*(x<1)*(y<2))
if Max_variable is always >0 but you need to tweak the constants and the rest to adapt to your case
Note though these Bolean maxop are very demanding on the processing and can take quite some time, it's always faster to partition the boundaries and select entire boundaries entities
COMSOL Employee
10 years ago
2015年11月13日 GMT+1 17:04
For essentially the same reasons discussed here
www.comsol.com/community/forums/general/thread/90392 we would not recommend using boolean operators for this. Partitioning at the geometry level is a better idea for accuracy.
For essentially the same reasons discussed here http://www.comsol.com/community/forums/general/thread/90392 we would not recommend using boolean operators for this. Partitioning at the geometry level is a better idea for accuracy.
10 years ago
2015年11月14日 GMT+1 17:32
Thank you, David and Ivar. I proceeded with the masking suggested by Ivar after exporting the data - seemed quickest.
Thanks Jeff, for the note of caution.
